Username:
Password:
Pages: 1 [2] 3 4 ... 8   Go Down
  Print
Author Topic: Scott's 1993 Boosted SL2 (Updated: Apr. 26, 2010)  (Read 10252 times)
morgansonsc2
Trade Count: (0)
Offline Offline
« on: May 28, 2008, 06:27:11 AM »
tk23,  sweet, sounds good on the cam spec. I had assumed you were useing the stock profile.
Logged
_________________
____________________
It is the road never traveled that leads to regret. It is the wrong road
chosen that leads to doubt.
It is better to travel in doubt, than to live in regret...
tk23
Trade Count: (0)
Offline Offline
12 Second SL2 (this year)!
WWW
« on: May 28, 2008, 09:16:17 AM »
Quote from: "morgansonsc2"
Smiley.
Logged
Scott S.
1993 Turbo SL2 - 13.259 - 110.10 MPH, 1.87 60' - 16 PSI
1995 Automatic SL2 - 14.318  - 99.19 - (Only a 75 Shot, Tapered TB, Exhaust Dump, Semi-CAI) -200,000k.
http://www.scottjsousa.com/tsn - TurboSaturns.Net Resurrec
morgansonsc2
Trade Count: (0)
Offline Offline
« on: May 28, 2008, 10:23:02 AM »
:thumbsup: sweet, +1 for duration. Lol
Logged
_________________
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 02, 2008, 10:48:11 PM »
Update 06/02/08:
Pics as promised!! As of now the engine is not in the car yet (my cousin couldn't get the hoist this weekend). It is probably 80% complete. I just ordered an intercooler (29x11x3) and piping and a universal BOV. There are about three big expenses left for this project (exhaust, slicks, and windshield).
The valve cover gasket is awesome! I think that we've found the best way to get oil to the turbo. We drilled and tapped the stock engine plugs and it works perfectly. No adapters (see pics) :)! We also made a custom front seal installer out of my old crank gear (see pics again).
Updated Cam Specs
While these will not be 100% accurate, they are close. Watch the video at the end of this post to see what we did to the cam gears. Using a dial indicator, we determined that the play in the stock cam gears was: .016 on the intake cam and .018-.019 on the exhaust cam. After come calculating, we determined that we should make the play on the intake cam .080 and the play on the exhaust cam .100. This actually retards both cams.
Intake Centerline: 109
Exhaust Centerline: 108.5-109.5
Intake Opens: 6.5 ATDC @ .050
Intake Closes: 28 ABDC @ .050
Exhaust Opens: 30.5 BBDC @ .050
Exhaust Closes: 8 BTDC @ .050
Now for the pics...
Cylinder Head Assembly 1
Cylinder Head Assembly 2
Main Plastigage
Rod Plastigage
Engine Assembly 1
Forged Rods/Pistons
Forged Piston
Engine Assembly 2
SCAT Rod on Crankshaft
Rear Main Seal
Girdle (Tie-Plate)
Engine Assembly 3
Engine Assembly 4
Engine Assembly 5
Lifters
Engine Assembly 6
Degreeing The Cams
Dial Indicator
Packed Oil Pump
Engine Plugs Tapped
Valve Cover Gasket
Engine Assembly 7
Stock (19 lb) vs. 55 lb Injectors
Front Seal Tool
Engine Assembly 8
Cam Modifications
Logged
Scott S.
morgansonsc2
Trade Count: (0)
Offline Offline
« on: June 03, 2008, 06:40:04 AM »
Yeah baby! That is sweet as hell. What is up with the head? i dont remember my head being half pentroof and half clover.
Logged
_________________
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 05, 2008, 09:03:40 PM »
Slight Update 06.05.08
Just hogged out the exhaust housing on my turbo to match the flange that I bought. That is all for today. Engine is still not in the car :? (maybe Sunday?).
Logged
Scott S.
morgansonsc2
Trade Count: (0)
Offline Offline
« on: June 06, 2008, 06:32:12 AM »
On the intake side you see that the quench zone extends in between two intake valves, this is called a cloverleaf. Arguably this is a good thing. If you look at the exhaust side it is roughly flat leaving an open gap in between the two exhaust valves, this is called pentroof. These designs refer to the "quench" zone of the combustion chamber. These raise compression and force the flow of fuel into the center of the chamber. I must say, this is one thing we have on hondas. They come with this weird circular chamber that wont burn all the fuel. that is why so many honda owners weld the head into a pentroof or a cloverleaf. If we had a perfect cloverleaf and flat valves our compression would be like 10.3 or something of that nature. Just remember that when the piston rises it forces the fuel out of the quench zones and closer to the spark. So a head design that facilatates this act (especialy on a N/A) is a good thing.
Logged
_________________
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 06, 2008, 07:59:32 AM »
Hmm good info there, thanks Smiley. I'll post some pics tonight.
Logged
Scott S.
morgansonsc2
Trade Count: (0)
Offline Offline
« on: June 06, 2008, 03:23:49 PM »
No problem, good luck looks good so far
Logged
_________________
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 06, 2008, 11:21:55 PM »
Camera batteries died damnit! Intercooler is sweeeeeet though :)!
Logged
Scott S.
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 09, 2008, 11:41:56 AM »
The engine is in the car :) (no turbo). I hope to have it running by the end of this week (N/A for now). More updates soon!
Logged
Scott S.
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 12, 2008, 10:58:19 PM »
Quote from: "tk23"
The engine is in the car Cheesy Oil pressure is excellent (30+/-psi at idle)!
Logged
Scott S.
JRSTANGE
Trade Count: (+2)
Offline Offline
WWW
« on: June 13, 2008, 08:43:54 AM »
hot idle or cold idle? glad to hear it running.
Logged
God bless boost!
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 13, 2008, 10:05:09 PM »
Quote from: "JRSTANGE"
hot, cold is around 60+ (short term memory loss lol)
Logged
Scott S.
JRSTANGE
Trade Count: (+2)
Offline Offline
WWW
« on: June 16, 2008, 08:51:57 AM »
sounds great!
Logged
God bless boost!
KiltedDemon94
Trade Count: (0)
Offline Offline
WWW
« on: June 16, 2008, 12:04:41 PM »
damn sounds great
Logged
I wont bow to something that I've never seen..........I can't believe in something that doesn't believe in me....I'm not blood of your blood.....I'm no son of your god...I'm have no faith in your faith, still I find salvation
Quote from: "omgitselvisc"
im vinny's bitch i guess lol
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 17, 2008, 04:55:32 PM »
sounds great!
Quote from: "KiltedDemon94"
damn sounds great
Thanks guys :)!
Logged
Scott S.
tristanlee85
Trade Count: (0)
Offline Offline
WWW
« on: June 29, 2008, 11:10:35 PM »
After seeing those pistons, my compression has to be a lot higher than yours. Plus I have the head shaved .030".
Mine:
Yours:
Logged
Tristan
1997 Turbo Saturn
MegaSquirt Repository (in the works)
http://megasquirt.cfcoding.com
Ralliart16
Trade Count: (0)
Offline Offline
:D
« on: June 29, 2008, 11:16:25 PM »
Care to explain to me why you used a degree wheel when you have stock cam sprockets that are non-adjustable..... I didn't really read your thread, so maybe I missed something lol  Also IIRC you're supposed to use a solid lifter to measure valve lift with a dial indicator like that.
Logged
Lean Fibaz Crew - Member #001
tk23
Trade Count: (0)
Offline Offline
WWW
« on: June 29, 2008, 11:24:38 PM »
Quote from: "Ralliart16"
Quote from: "tk23"
Update 06/02/08:
The valve cover gasket is awesome! I think that we've found the best way to get oil to the turbo. We drilled and tapped the stock engine plugs and it works perfectly. No adapters (see pics) Tongue. I know they wont be 100% accurate, but they will be close. We weren't trying to find out lift, we just wanted change when the valves open and close and change the cam's centerline so they would be closer to my dads cam that he had on his Turbo T-Type.
Logged
Scott S.
tk23
Trade Count: (0)
Offline Offline
WWW
« on: July 09, 2008, 10:59:58 AM »
Note: Same post as in "What's Going On" section, just to keep this project organized.
:D!
After hours and hours of fabbing and what-not, the manifold is done! We welded it up last night at my dad's work. We didn't have the car there so it was basically all or nothing. When we got home, we test-fit it on the car and it really couldn't have worked out any better! I love the design, and yes I can still have the A/C. Most if not all of the credit goes to my dad for this. I just have to clean it out a little bit, but other than that it's ready to go. Now on to exhaust...lol.
Pics:
Logged
Scott S.
JRSTANGE
Trade Count: (+2)
Offline Offline
WWW
« on: July 09, 2008, 11:44:34 AM »
looks great still. almost there.
Logged
God bless boost!
tk23
Trade Count: (0)
Offline Offline
WWW
« on: July 09, 2008, 09:15:41 PM »
Haha, so close...yet so far (exhaust, poly dogbones, new windshield, and most importantly tuning).
Logged
Scott S.
serenitythen
Trade Count: (0)
Offline Offline
« on: July 09, 2008, 11:44:32 PM »
The smooth transitions from the manifold to the turbo looks like it should flow great.
Cool project!
Logged
morgansonsc2
Trade Count: (0)
Offline Offline
« on: July 10, 2008, 06:15:12 AM »
Damn, that "header" looks good. Great job.
Logged
_________________
Pages: 1 [2] 3 4 ... 8   Go Up
  Print
Jump to:
Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC
DarkBreak by DzinerStudio
Page created in 1.103 seconds with 48 queries.
