Username:
Password:
Pages: 1 ... 6 7 [8]   Go Down
  Print
Author Topic: Scott's 1993 Boosted SL2 (Updated: Apr. 26, 2010)  (Read 10245 times)
tk23
Trade Count: (0)
Offline Offline
12 Second SL2 (this year)!
WWW
« on: April 26, 2010, 10:26:23 PM »
Update: 04/26/10
The car is now on the road again. It feels good to actually drive a car that has some power. I have done a lot over the winter, and there is plenty more to do. I thought that the transmission was bad, but it turns out that the syncros were fine. I replaced the little plastic guides on the end of the shift forks, but other than that, the transmission remains the same.
I made my own hood piston kid with the help of my dad. It uses two 40 (?) lb pistons. I really like the way that it turned out.
I also added KYB struts and H&R Sport springs to the car. The car is noticeably stiffer (better for the drag strip). I also added polyurethane LCA and sway bar bushings. I like the way it rides now. I still have that sleeper look.
I added the boost controller from DIYAutoTune to the car (I have yet to program it). I fixed my turbo drain as well. I also added another relay to control the Volvo slim-fan's slow speed circuit through the MS. I also upgraded the firmware, and I don't have the spikes that were there before. However, I still have a few things to work out with the tune.
Things to-do in the near future: Clean/Polish paint and switch valve cover and paint the "new" one the same color as the car.
Pics:
Hood Piston Kit
Hood Piston Kit 2
Hood Piston Kit 3
KYB Struts/H&R Sport Springs
Interior Dismantled
Shift Cables
Clean Engine Bay
LCA Polyurethane Mount
Sway Bar Polyurethane Mount
New Oil Drain
Slow Speed Fan Relay (Before Proper Mounting)
Logged
Scott S.
1993 Turbo SL2 - 13.259 - 110.10 MPH, 1.87 60' - 16 PSI
1995 Automatic SL2 - 14.318  - 99.19 - (Only a 75 Shot, Tapered TB, Exhaust Dump, Semi-CAI) -200,000k.
http://www.scottjsousa.com/tsn - TurboSaturns.Net Resurrec
tristanlee85
Trade Count: (0)
Offline Offline
WWW
« on: April 26, 2010, 10:33:48 PM »
Are those the Dorman shift cables from Advance Auto?
Logged
Tristan
1997 Turbo Saturn
MegaSquirt Repository (in the works)
http://megasquirt.cfcoding.com
lilcraigford
Overkill Since 1987
Trade Count: (+1)
Offline Offline
...what a waste!
WWW
« on: April 26, 2010, 10:47:05 PM »
Car is looking good!
Logged
94' Saturn SL2: The "Detail Junky"
(15.652 : 88.36 mph)
96' Saturn SC2: The "Daily Junky"
WTB (Minty Fresh)
- 1991/94 S-Series Non-AC Climate Control Unit
- 1995/96 SC2 Front Fascia
- 1991/02 SC2 Leather (Black Rear)
tk23
Trade Count: (0)
Offline Offline
WWW
« on: April 26, 2010, 10:49:58 PM »
They are the Dorman shift cables, but I'm not sure if they are from Advance. I bought them from a member on here. Speaking of those, I forgot to mention that I have an issue with the up/down shift cable...it seems to be binding up. 2nd, 4th and reverse feel weird. I have figured out that it's a problem underneath the console where the shift cable sleeve is "bending". I will figure out a solution soon.
Thanks man!
Logged
Scott S.
tristanlee85
Trade Count: (0)
Offline Offline
WWW
« on: April 26, 2010, 11:02:23 PM »
That's why I asked. I had those same cables and it made driving impossible. When you would try and shift up or down, the cable would bend. DasPirate and I rigged it up with speaker wire rigged up around the cable and bolted the wire to the shifter so it would always be pulling on it and not allow the cable to bend. This at least got me home from PA. I took them back ASAP and got a refund, went to the junkyard and found some 94 cables that have a metal sleeve around the cable. It's worked perfect ever since.
Logged
Tristan
1997 Turbo Saturn
tk23
Trade Count: (0)
Offline Offline
WWW
« on: April 27, 2010, 06:18:00 PM »
Good to know...too bad I bought them from a member on here.
Logged
Scott S.
tk23
Trade Count: (0)
Offline Offline
WWW
« on: May 10, 2010, 12:47:56 PM »
Not really an update, but I did contact Dorman as it is impossible to shift...oh and here is a new pic:
Logged
Scott S.
lilcraigford
Overkill Since 1987
Trade Count: (+1)
Offline Offline
...what a waste!
WWW
« on: May 10, 2010, 03:01:58 PM »
Car looks effin' clean in that picture!
Logged
WTB (Minty Fresh)
tk23
Trade Count: (0)
Offline Offline
WWW
« on: May 10, 2010, 03:35:57 PM »
Thanks, just washed it. I wish the paint was in better shape lol.
Logged
Scott S.
saturntech95
MIKE
Trade Count: (0)
Offline Offline
District 4 Offroad, Diesel & Performance
« on: May 10, 2010, 10:56:11 PM »
I saw you today pulling out of pick a part in freetown just as I was pulling in. I was gonna call you and tell you to turn around but I couldn't find your #.... Bummer, I havent seen this thing in person and I live within 20 minutes of you and my shop is like 5 minutes. One of these days LOL. Does look good tho.
Logged
WARNING: The following posts may contain and are most likely the result of any/all of the following. Boredom, laziness, apathy, lack of sleep, alchahol and a strong desire to be a jackass for no good reason other than because I can and am. Please read and take any or all posts with a grain of salt and a sense of humor. Not responsible for any butt-hurt, bad attitudes, or temper tantrums. By reading this, you have accepted this warning as a warning, therefore you have been warned, Thank you.
tk23
Trade Count: (0)
Offline Offline
WWW
« on: May 10, 2010, 11:39:08 PM »
I wont be around this weekend. I have class tomorrow and Wednesday is going to be crappy. When are you usually free during the week/weekend? I'll gladly meet up with you if I'm not busy. I have finals next Tuesday and then I am finally done with college!
Logged
Scott S.
saturntech95
MIKE
Trade Count: (0)
Offline Offline
« on: May 10, 2010, 11:58:36 PM »
Sunday and monday are my days off but I will be in DC this weekend. I'm shure I'll see it sometime it was just kinda funny I saw you pulling out and went right by you, I was in my truck tho orelse you probobly would have recognized me.
Logged
tk23
Trade Count: (0)
Offline Offline
WWW
« on: May 11, 2010, 08:08:00 PM »
Was it a gray truck? I vaguely remember seeing a truck when I was going over the railroad tracks.
Small update on the car: Dorman is willing to send another set of cables to me (their re-designed version).
Logged
Scott S.
saturntech95
MIKE
Trade Count: (0)
Offline Offline
« on: May 11, 2010, 11:40:56 PM »
Well dirty white...lol... ya that was me right at the tracks.
Logged
Pages: 1 ... 6 7 [8]   Go Up
  Print
Jump to:
Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC
DarkBreak by DzinerStudio
Page created in 0.562 seconds with 37 queries.
