Username:
Password:
Pages: [1] 2 3 ... 7   Go Down
  Print
Author Topic: Scott's 1993 Boosted SL2 (Updated: Feburary 04, 2010)  (Read 8594 times)
tk23
Offline Offline
12 Second SL2 (this year)!
WWW
« on: April 06, 2008, 11:31:25 AM »
I have not listed everything here because I am still unsure about certain items. I've probably forgotten some stuff too lol.
Background:
Well, I purchased this car in late June of last year (2007) but the idea of a turbo Saturn has been floating around in my head ever since I got my first one (about two years ago). It was listed at 76k miles, but I'm not totally sure on the actual mileage. A few documents that I found in the glove box say 176k. This car only cost me $1000. It has brand new tires, and A/C.
Pics from CraigsList Ad:
My Pic:
Goals:
My hopes are to finish this by late May 2008 in time to make the GM EFI Race at Raceway Park (Englishtown). I want this car to be able to be driven on the street and strip. It will have a mild setup on the street (probably no more than 10 psi of boost). At the track I will run in excess of 25 psi. I am going to use all "stock" Saturn parts (i.e. a Saturn intake manifold, throttle body, etc...).
I want to run a 12.5 e/t at the track at most. Anything more is a gift. Smiley)
Fan Switch
Progress and Various Pics:
 - T04E Turbo
 - SCAT Rod
 - MS Wiring 1
 - MS Wiring 2
 - MegaSquirt
 - MS Launch Control Momentary Switch
 - Gauge Pod with Boost and Wideband Gauges Installed
 - Tie-Plate (Girdle)
 - Manifold Progress
 - Engine Removal
 - Stock Internals
 - Valves
 - Head
 - Head Porting 1
 - Head Porting 2
 - Head Porting 3
 - Head Porting 4
 - Head Porting 5
 - Head Porting 6
 - Walbro Install 1
 - Walbro Install 2
 - Walbro Install 3
 - Walbro Install 4
 - ACT Clutch 1
 - ACT Clutch 2
 - ACT Clutch 3
 - DIY Volt Booster that I got flammed for on PR
 - Wiseco Piston Specs
 - Wiseco Pistons 1
 - Wiseco Pistons 2
 - Wiseco Pistons 3
 - Wiseco Pistons 4
Logged
Scott S.
1993 Turbo SL2 - 13.259 - 110.10 MPH, 1.87 60' - 16 PSI
1995 Automatic SL2 - 14.318  - 99.19 - (Only a 75 Shot, Tapered TB, Exhaust Dump, Semi-CAI) -200,000k.
http://www.scottjsousa.com/tsn - TurboSaturns.Net Resurrec
tk23
Offline Offline
WWW
« on: April 06, 2008, 08:03:07 PM »
More Progress:
Well I took the transmission apart today (MP3) with the help of my cousin...and I was kind of dreading how you have to take everything apart to get at the differential. But, after doing it, I realized that it was a real simple process. The tranny seems to be in very good condition. The pin, spider gears, and roll pin all look nice. I'm starting to think that even if this car had 176k miles on it, that the previous owner took very good care of it. Next comes the PG and welding of the diff pin.
Transmission Disassembly 1
Transmission Disassembly 2
Transmission Disassembly 3
Transmission Disassembly 4
Transmission Disassembly 5
Transmission Disassembly 6
Logged
Scott S.
tk23
Offline Offline
WWW
« on: April 08, 2008, 09:06:52 AM »
Well, today I brought everything for the turbo project to the machine shop. The guy is a long time friend of my dad and I know that he does quality work. I hope that it doesn't take too long lol. I really want to get this project done. :)
List of things that he's doing:
Balancing
Bearings
Re-surfacing Flywheel
Honing Block for more clearance for forged pistons
Machining Rods so they fit into pistons (sides, tops, and boring out bushing a couple thousanths)
Polishing Crank
Logged
Scott S.
JRSTANGE
Offline Offline
WWW
« on: April 08, 2008, 09:57:26 AM »
awesome!
Logged
God bless boost!
The Shaolin
Ooh, a lesson in not changing history from Mr. "Im-my-own-grandpa!"
Offline Offline
I break things.
WWW
« on: April 08, 2008, 10:49:38 AM »
You're going to have a hell of a time getting that trans back together.
Good progress though.
Logged
Active:
1995 SC2
2000 VW Jetta Turbodiesel
In Progress:
1986 RX7
In Storage:
2000 SC1-Blowed up
1974 Honda CL125S-No snow tires Sad
tk23
Offline Offline
WWW
« on: April 08, 2008, 06:33:17 PM »
Quote from: "JRSTANGE"
awesome!
Quote from: "The Shaolin"
Thanks. It shouldn't be to hard...I have my FSMs if I forget anything lol.
Logged
Scott S.
tk23
Offline Offline
WWW
« on: April 16, 2008, 09:21:36 PM »
Got some more goodies today from the boneyard. Intake cam from a 95 wagon, fan/shroud from a Volvo 940 (not sure if this will work yet), and two steel rims for my slicks (with some decent tires mounted on them already). Also ordered an oil pump and .030 shims from SDA :).
Boneyard Run
Intake Cam 1
Intake Cam 2
Logged
Scott S.
mars_volta
Offline Offline
« on: April 16, 2008, 09:32:06 PM »
2 intake cams and a stock intake? 25 psi?  good luck.
Logged
95 SC2
05 Legacy GT LTD
tk23
Offline Offline
WWW
« on: April 16, 2008, 09:36:18 PM »
Quote from: "mars_volta"
Lol yeahhh buddy! :P. We shall see how everything holds up lol.
Logged
Scott S.
tk23
Offline Offline
WWW
« on: April 17, 2008, 11:24:29 PM »
A little more progress tonight: Got the Phantom Grip installed, and checked my wastegate. It seems to hold up to around 25-30 PSI so I'm excited :)! My dad will be welding the diff on Saturday.
Pics of Progress and Turbo:
Phantom Grip 1
Phantom Grip 2
T04E 1
T04E 2
T04E 3
Logged
Scott S.
tristanlee85
Offline Offline
WWW
« on: April 17, 2008, 11:27:47 PM »
it the angle of the picture, or do the rods not fit into the piston?
Otherwise, the progress looks good.
Logged
Tristan
1997 Turbo Saturn
MegaSquirt Repository (in the works)
http://megasquirt.cfcoding.com
tk23
Offline Offline
WWW
« on: April 18, 2008, 08:32:05 AM »
Quote from: "tristanlee85"
No it's not the angle of the pic, you are correct. I had the machine shop take some material off of the top of the rods (because due to the way that the pistons are made: the strength of the piston is where some material would have had to be removed). Ricesucks!!! told me that he had to get some material removed from this same job number (00711-2736, I think) from Wiseco. I'm not sure why these pistons are made this way? But, the machine shop called me this morning and I'm going to grab all the stuff in a little bit. I should have some new pics up shortly.
Thanks for the comment :).
Logged
Scott S.
JRSTANGE
Offline Offline
WWW
« on: April 18, 2008, 09:19:38 AM »
wow, internal wg with a boost reference port for say a ebc. interesting.
Logged
God bless boost!
Pimped_SC2
Most Hated 6s Member #1
Offline Offline
« on: April 23, 2008, 09:05:45 AM »
Since when did ACT make a sprung 6 puck?
Logged
JRSTANGE
Offline Offline
WWW
« on: April 23, 2008, 02:17:25 PM »
as of the last year or pretty recently.
Logged
God bless boost!
tk23
Offline Offline
WWW
« on: April 23, 2008, 02:17:38 PM »
Quote from: "Pimped_SC2"
Since about a few weeks ago :). It's on their site, the part number is ST1-HDG6 I think...
Logged
Scott S.
tk23
Offline Offline
WWW
« on: April 25, 2008, 12:30:05 PM »
Update (04.25.08):
Well I checked the crank (mains/rods) with Plastigage and it checks out. Bearings will be on the way shortly. I have Windo-Welded the TAM and transmission mount. The transmission is together. But, while putting it together, I almost snapped a bolt lol (check out the pic below). Also, I got everything back from the machine shop last Friday.
Welded Differential
Transmission Assembly
Stretched Bolt
Forged Pistons/Rods 1
Forged Pistons/Rods 2
Forged vs. Stock
Logged
Scott S.
tk23
Offline Offline
WWW
« on: May 01, 2008, 07:05:02 PM »
There has been a little delay with my project. School is crazy right now due to this being one of the last weeks. I am done by May 14th though. Here's a slight update: I should have the head back together by Sunday (but I am not sure on this). I have already started to clean the valves, use grinding compound on the head, etc... I just received my bearings from eBay and I'm also going to try to get the bottom end put together by this week. The deadline is not May 30th anymore because I will not be attending the GM High-Tech Performance race. However, once I am out of school, I should really have the ball rolling :). I hope to be done sometime in June.
Logged
Scott S.
yillo
Offline Offline
« on: May 01, 2008, 08:01:19 PM »
sweet
Logged
T.P.R.............................Texas Performance Ridez
94' Sl2---header-2.5 exhaust no cat-intake-MSD coils----GONE(IT'S BACK)
99' Cadillac--stock
89' Ford Ranger----stock
ricesucks!!!
Offline Offline
« on: May 01, 2008, 11:50:50 PM »
damn, 25-30psi?  we better see 450hp!!!
good luck with everything!
Logged
tk23
Offline Offline
WWW
« on: May 04, 2008, 03:32:50 PM »
Quote from: "ricesucks!!!"
LOL I highly doubt 450 Smiley. Thanks for the comment though!
I was thinking of putting the bottom end together today, but the weather is shitty and drag racing is coming on soon (and by soon I mean 2.5 hours lol). Too much school work to do too ugh :(.
Logged
Scott S.
tk23
Offline Offline
WWW
« on: May 21, 2008, 10:41:20 AM »
I've been working here or there on this project, but since my grandfather just passed away, I haven't had much time. I do have the crank in the motor and I'm going to be working on it again today :). I'm glad that I can finally get some stuff done. Pics soon!
Logged
Scott S.
morgansonsc2
Offline Offline
« on: May 27, 2008, 03:24:09 PM »
what is this thing going to be boosted at. Will a stock block hold up to 30 psi? I mean, dont get me wrong, it all looks great but i think you may see about 300, but i dont think the engine is going to hold together. Other than this minor detail it looks amazing and well thought out. If you took the time to get some real turbo cams you could easily see 350.
Logged
_________________
____________________
It is the road never traveled that leads to regret. It is the wrong road
chosen that leads to doubt.
It is better to travel in doubt, than to live in regret...
tk23
Offline Offline
WWW
« on: May 27, 2008, 10:39:12 PM »
Quote from: "morgansonsc2"
Thanks for the compliment man. I'm not sure how much it can hold but we'll see haha. Motor is probably around 60% back together as of this point and it will probably be back in the car by the end of this week. As for the cams, I have taken some material out from the key-way to retard both of the cams. This puts the centerline of both of the cams at about 108-109. Intake opens at about 6 ATDC and exhaust closes at 9-10 BTDC at .050. I did this because I was comparing some Buick turbo cam spec sheets with my cam specs. Pics will be up soon, as stated before, but probably once the engine's back in the car.
Logged
Scott S.
d3ad1ysp0rk
Offline Offline
« on: May 27, 2008, 11:02:34 PM »
Quote from: "tk23"
Wanna hold off on finishing til I get the AIC working, so I can rock the claim to "New England's fastest Saturn" for a little while at least...?  :lol:
Logged
Your Ad Here
Pages: [1] 2 3 ... 7   Go Up
  Print
Jump to:
Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC
DarkBreak by DzinerStudio
Page created in 0.902 seconds with 22 queries.
