Results 1 to 11 of 11
  1. #1
    Steering wheel is locked and key wont turn...
    i jiggled the steering wheel for about an hr or so and still cant get the key to turn. Is there like and "o shit release button" or anything i can to do to get the key to turn. Or is there a post somewhere on how to change the key/starter/ignition switch or how to unlock the steering wheel.
  2.    Sponsored Links
  3. #2
    Ubiquitous Administrator Donnie's Avatar
    Join Date
    Apr 1992
    Location
    Chicago.
    Posts
    8,274
    Blog Entries
    1
    Re: Steering wheel is locked and key wont turn...
    How worn is the key?
    Your friendly brand traitor Administrator.
    372/425 @ 20PSI. More to come, 400WHP or bust!
  4. #3
    no magic release, gotta figure out either the sweet spot for the key, or which is too worn, the key or the ignition.
    i tryed my key and my spare key... so now my guess is the ignition is shot.... are there any how to's? or is it simple? I have done alot of work on cars but never had an igniton go out...
  6. #5
    where did your spare key come from?
    you might be better off getting a key cut from saturn
    if you buy a different ignition lock cylinder, then you can change the wafers to fit the new key
    -broken -rust -TAURUS [stock] 181k
    Bought a key from a gm dealer. Still wont turn the ignition. How do i go about changing the Ignition switch? like how do i get it out and how does it go back in?
    Is this what i need?
    http://www.autozone.com/autozone/acc...er=103784_0_0_
    EDIT: Just found a vid on how to get the cylinder out. How am i supose to the cylinder out i cant turn the key to acc????
  8. #7
    Still cant get the key to turn at all. So i figured id just replace the whole ignition key assembly and the steering wheel is locked and i cant get to the bolts on the back side to get the airbag off...
    So i am kinda stuck and now thinking i have to replace the whole steering column. Any ideas would be appreciated
  9. #8
    you might have to get a small drill bit and drill both sides of the wafers out and then break what's left to turn it to remove it
    you did turn the steering wheel off the lock right? the ignition wont turn with the wheel holding pressure on the locks
    93 SC1.5m DD; finally runs
    90 300ZX TT; $800 diamond in the rough
  11. #10
    Super Moderator S.Bretz's Avatar
    Join Date
    Apr 2004
    Location
    Lutz, Fl
    Posts
    10,244
    Turn the wheel to the leftto pull it off the lock. Like mentioned, it you are trying to turn the key with pressure on the lock, it will not turn.
    1995 Sc2 no powertrain MS3.
  12. #11
    i know how to unlock a steering wheel. The key would not turn no matter what way the steering wheel was or how much i jiggled it.
    NEW problem new post new title...
    http://www.sixthsphere.com/smf/index.php?topic=63089.0
Posting Permissions
  • You may not post replies
  • You may not edit your posts
